99 4R44E replacement question, front driveshaft removal
amanda11270
Harrisburg PA
V6 3.0L
How does the front driveshaft remove from the transfer case? I have seen the front axle U joint before, but never the type on the transfer case, how does the front driveshaft remove from it? Just pull out, or does it unbolt in some way?
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
There's 6 or 8 bolts to undo.
projectnitemare
8
Osceola Mills, Pa
396W
There are 6 8mm head bolts. Unbolt them and give a good tug.
Matt
