97 ranger 3.0 Ignition switch
variable70
Having an intermittent ignition switch problem. Put the key in and its as if the battery is dead. Battery is good, alt is good. Then all of a sudden it fires right up like normal. Is that a bad ignition switch? The switch kind of moves around in the colum like its loose. I have never had an ignition switch go bad so I am not sure what the symptoms would be. Anyone have any insight they would like to share?
variable70
update
So its no power anywhere, no headlights nothing. If I disconnect the battery then reconnect it I get power but once i try to turn the truck over it goes back to no power anywhere.
variable70
fixed
Turns out it was a loose ground.
