runningslow
- Feb 8, 2010
- 1
- Davenport, FL
- Ford
- Engine Size
- 2.3L
I've got a '97 2.3L manual with about ~250k on the clock. The past week or so, the truck has been tripping em up.
On my morning commute with outside temps in the mid 60s, all is well and no problems.
In the afternoon with outside temps in the upper 80s, it'll idle at about 800 rpm, then it seems to want to stall (rpms drop) then it surges to about 2000 and eventually settles back to about 800. Yesterday, it actually stalled on me a few times when stopped.
Anytime the truck is moving, city or highway, I'll feel the truck occasionally hestitate, buck. When it does, I see the check engine light blink off and come back on. I don't see the tach needle move.
Truck has had a constant CEL since I bought it three years ago. I pulled the codes a few days ago, after the problems started, and it had the same two codes it has had for a long time: P1443 & P0420. Truck has no CAT and speedometer doesn't work.
Thoughts??
I'll add that I had a similar issue before that went away after replacing the camshaft position sensor, but that time it was a throwing a code.
Thoughts??
