Rocker3829
- Mar 30, 2009
- 0
- Ford
Hey y'all, would greatly appreciate any help y'all can give with my question here.
I am replacing the Slave Cylinder (some occasional noise in the clutch when it engages and disengages, troubleshootin guide from the manual and some people I've talked to point toward this being it) and obviously have to remove the transmission. I am having problems pulling the transmission off the motor. I have followed the instruction list in the manual but am wondering if I have missed a couple of bolts attaching the motor to the tranny. I have removed 6 bolts (two at the bottom of the transmission, one a few inches above the starter, one equivalent to above the starter on the other side, one about 6 inches higher than the starter near the exhaust pipe, and one just beneath the oil filter) and the two above that) that connect the two (as well as having already removed the transmission mount, electrical connections to the tranny, the driveshaft, starter, shifter, and pushrod from the clutch, as well as already disconnecting the battery), does anyone know how many bolts attach the motor to the tranny by chance? I do have a jack with a wood block supporting the engine from underneath and a jack with a wood block supporting the transmission.
Sorry for the blob of info, but any help would be greatly appreciated.
Some random info on the ranger that might help
96 2.3L SLT Ranger
Just under 221,000 miles
I bought this from a friend Dec. 2004 w/ 154,935 miles on it (first time I've had any problems with anything in the clutch assembly)
96 2.3L SLT Ranger
