95 Ford Explorer SAS build
3rd Petal
Northern NV
Copied over from my local 4x4 forum
This project started out as a dirt cheap budget build from a salvage titled Explorer and miscellaneous junk I had laying around.
But as time went by and parts were broken, as many people would, I became bored with a very mild, mostly stock, trail beater. So it got parked and set on the back burner for a few months. But now it's back and going under the knife. A general overview of the current plans are, spring over rear (8.8), SAS front (D44), 37's, custom reduction box, and custom front/rear bumpers.
To start I tore out the old spring under rear end. Then added some 3/8" shackles, cause the stock stamped ones wouldn't cut it
Then a simple 8.8, with custom rocker perches to try to get just a bit more out of the leaf springs
3rd Petal
Northern NV
All of this has been cut out
To be replaced with this
By means of these
3rd Petal
Northern NV
A little work with the tubing bender so the radius arms will clear the tires
3rd Petal
Northern NV
Got some frame end brackets built for the radius arms, then finished up the main links and built new 1 3/4" .250 wall upper links, didn't think the 1 1/4" ones would cut it.
Then mocked up under the vehicle
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
interesting setup :icon_thumby:
drive shaft ok through full cycle?
i dont think they would live long with me in that configuration
3rd Petal
Northern NV
Thanks. DS should be just fine, don't see why it wouldn't be. But I don't have a t-case in it yet, so we'll see how it looks once I get my doubler and t-case bolted on
