95 8.8 LSD Oil Change
mxboy349
Changing the oil in my 95 8.8 LSD. I got 80w-90 "Limited Slip" oil. Do I need the friction modifier?
19Walt93
4,488
Canaan,NH
351
3"
235/55R16
What brand is the oil and what does the bottle say? Motorcraft gear oil requires friction modifier.
8,372
If it says "Limited Slip" oil then the friction modifier is already mixed in
The friction modifier allows the clutch packs to slip better when going around corners, without it you would hear/feel a jittering from rear axle as the clutch packs were not slipping easily, so not smooth cornering
Friction modifier doesn't hurt anything to use it in OPEN differentials
mxboy349
Castrol 80w-90 Limited Slip GL-5 is what I got.
8,372
Should be fine
