94 ranger sas
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
She's comin along nicely bud!
captainsa
Been getting a little done here and there. Motor , Trans and case are mocked up. Been gathering parts also.
jesselee20040
Hobbs, NM
2.9 about to swap in 2.3 turbo diesel
So other than the vortec motor, what is the rest of the drivetrain? I have a 5.3, 4l80e and np205 that i would like to put in my bronco ii.
captainsa
Drive train is aluminum 5.7 block with truck heads and intake, 350 turbo , ford 205. Axles are a 9" and dana 44 out of late 70's full size f150. I purchased adapter to go from the 350 turbo to the Ford tranfer case from advanced adapters
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Why not just install a chevy 205 input gear?
SVT
captainsa
Explain what you mean
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Chevy 205's should bolt right up to the turbo 350 (unless you have the figure 8 pattern), both the chevy and ford round 6 bolt pattern are the same, so just install a chevy 205 input gear into the ford 205 case and bolt it up...
SVT
captainsa
The only chevy adapter I found they wanted as much as the advanced adapter. I was told the Ford had a stronger input.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
captainsa
Mines a 6 bolt, and I see the part your talking about but the peice that bolts between the Trans and the case is the difficult part, this is what I ended up getting
jesselee20040
Hobbs, NM
[/URL][/IMG]
I like this option of mounting the two together with my short wheelbase.. He used the short 32 spline chevy input in the ford case and shortened the trans output shaft down to match, all with using 1.25" adapter.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
That looks like a pretty sweet setup!
jesselee20040
Hobbs, NM
Can you post a few pictures around the sides and the back of the engine? I am curious to see how much room there is for headers/exhaust.
Thanks
captainsa
Drivers side
Passenger side
captainsa
I have a chance to buy these wheels and tires at a decent price, what do you guys think get them or pass
No members online now.
