94 Fonefiddy PS pump reservoir swap
jerkyboyxiii
89
nebraska
ford ranger
My PS pump started howling. Im sure it's the original, so I'm just gunna replace it in order to preserve my belt in case it freezes up. Got the new pump from NAPA; it does not have a reservoir. Fine! Ive never replaced a rervoir. The hyd fitting should be the only thing holding the reservoir on the pump, correct?
jerkyboyxiii
89
nebraska
ford ranger
NVM. Gump waited too long to reply:) I finally found the answer I needed on ford trucks website...
alwaysFlOoReD
5,136
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
jerkyboyxiii
89
nebraska
ford ranger
Ha! Sure. I had to remove the pressure valve feom the reservoir. It is where the pressure line thrads into. Once that is no longer holding the reservoir in place, the reservoir can be tapped off:)
