Steve777
- Dec 23, 2017
- Reaction score
- 0
- Location
- Colorado
- Make / Model
- mazda
- Engine Size
- 4.0l
- Manual
Noticed the battery light on while driving today; made it home OK and then started checking the battery voltage. About 12v with the engine off; drop to 11.7v or so at idle and does not get any better if the engine is rev's up. Battery charges up just fine on an AC charger (which I am doing now).
So normally I'd assume its the alternator, but before I rush out to buy a new one I thought I should check the fusible links (which I assume this car has). I don't have a wiring diagram, but I would guess there are two links, a big one on the main power line and a smaller one on the voltage sensing line to the alt. I was looking for an easy way to test if these are good without digging around the wiring harnesses, and had a couple of thoughts:
On the big one, I would assume if there is batt voltage at the big terminal on the alt then its fusible link is good. Same with the sensing wire, but probably have to have the ign on and maybe the engine running to see voltage there.
Does this plan sound right? Any other ideas? Or does someone know where these fusible links are?
TIA
TIA
