SkiLLzWheeLz
- Oct 16, 2008
- 0
got a code today....drove it to town again....did about the same...when I turn the truck off and start it back up while coasting down the road, it gets gas as it should most of the time and goes for about a minute or two sometimes until it does it again. Check engine light came on and went back off at least 7-10 times while driving. Came home....no CEL....tried to pull the codes anyway to see what would happen......
So the code....I think I got code 172:::::
Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
When my check engine light comes on when the wires are jumped it goes as follows....
1 superfast dim blink......3 second delay
1 longer blink.....3 second delay
maybe code 111?..if so, it means "system check ok"...I can tell that the ecu must be running a system test because I can hear the fuel pump turn on for a 2nd time at the beginning of the blinking.
AFTER that code repeats itself again,
6 second delay.....
1 longer blink....2 second delay
7 fast short blinks....2 second delay
2 longer blinds....then repeats itself again.
So there is what Im working with......Maybe the o2 sensor...but would it make the truck bog down like that? Even at normal gas it still tries to bog down and will not accelarate most of the time.....
Also, my gas door has been shaved by the PO. There is a spot cut out in the bed to add gas to the tank. The gas cap is a screw in type and the filler neck piece doesnt have threads. It still holds in there but Im sure it doesnt create a perfect seal.....would this cause any problems? I doubt it as the truck did run fine before and still had that bad gas cap.
6 second delay.....
