92 2.3: Front crank oil seal carrier?
zekew64
Carbondale, IL
2.3L I4, rebuilt from a '91
Hey all. I have a (somewhat big) problem (may have posted this somewhere else, can't recall).
I'm rebuilding my 2.3 with 2.5 internals. The problem is, I broke in three places the aluminum oil seal carrier -- and it is integrally-related to putting the oil pan back on.
What I need to know is: Parts options. Does anyone know of a site that may sell a new part? Does anyone know of what the thing is called, and/or know the part number?
The part I'm referring to is this:
It is the aluminum part, on the front of the 2.3 that the front end of the crank is fed through to attach the timing gear, protect the timing belt, and behind the timing gear, holds the front crankshaft oil seal (main seal). This machined chunk of aluminum also has part of the oil pan mating surface. Because I broke mine removing the stupid timing gear (D'oh!), I now need a replacement.
Can anyone help me out here?
8,372
Found this part number: E9TZ-6019-C for 1989 to 1992 2.3l
And this one for 1993/4: F3ZZ-6019-C for 2.3l
They call it a timing cover, but its not the only one so...........................
black_demon69
142
AZ
4.0l
Get a good welder to tig it for you and repair it. Just throwing that option out there.
