91 explorer vibration
AKBroncoII
Happens right at 65 and over. Very annoying. Just swapped tires so I know it's not the tires. Redid the rear driveshaft ujoints in December. Wheelbearings, balljoints and all steering is tight. Happens in 4th gear and 5th gear. Vibration doesn't change when clutch is pushed in. Caster is good and so is my camber. Bent rear shaft maybe? I don't recall having this problem before I swapped my rear shafts out for the disked shafts when I did my rear disk swap. I've thought about my rear driveshaft not being ballanced but every time I've ever had a rear driveshaft issue on anything the vibration would change when disconnected from the engine which this does not. Any help or input (constructive) would be much appreciated.
