slamdstorm
- Jul 25, 2014
- 0
- Ford
I'm most likely going to be purchasing a 1990 2.9L automatic 4wd w/ electric shift extended cab ranger the first of the week. It shows 86,000 but I assume it has rolled over at least once. It was pouring today so I didn't even get her up to highway speeds before heading back. I'm wanting to find out what are some of the common issues seen with this version and what would make you pass up buying it. I've never owned a 4wd and am looking at it being a daily driver of about 5 miles asap.
Was told the last time in 4 low he had a heck of a time getting it out and sadly I don't remember what he said he did to get back to 2wd. I also don't remember if it has manual hubs or auto. Said 4 high has no problems so gonna test it first after highway and then finally 2low.
Said on occasion it won't start and he has no clue why. Popped battery in it and it fired after 3-4 seconds cranking and a pump or two on the pedal. Fired back up twice after test drive. Idles smooth and nothing noticable during drive. Are the injectors, in tank fuel pump and fuel pressure regulater interchangable with an 87 2.3L ranger? Already verified 87 injectors working and the regulator on it is new.
Windshield wipers don't work which is why it was a short ride but could be just a fuse. My concern is an electrical problem in dash. Anyone know if wiper wiring runs near 4wd switch or wiring back there? Radio, lights, and heater work fine. Would my 87 wiper motor swap out if need be?
A heads up with high dollar items that commonly go bad on the 2.9 to check would also be helpful. I know the 4wd info I have right now isn't much to go on but I can handle 2wd till I get it home and some time. The final question is would my 2.3L and 4 spd w/OD manual tranny slide into it in a crunch without having to change out rearend. Thanks for your time and help
