On the 2.9, It's located behind the distributor, not on the side of the Radiator.
So do you have spark coming from the coil at all? If so, then it's most likely that module. I don't know if this ever happened but if you find that the truck dies after running for a bit then runs when it's cooled down, That's a tell tale sign of a failed Ignition Module (Edis).
