'89 Bronco II build
JOSEPH169
12
Marysville, Wa
I'll post some pics soon. I ran into a lil issues with my superrunner system that was modded for 1 ton rods. The GM drag links are too long so I couldn't get enough adjustment for my toe in, I'm gonna have to get dodge 1 tons that i use on the outers as well for the drag links since they have more threads and are a lil bit shorter in length.
JOSEPH169
12
Marysville, Wa
Got my steering all aligned at work yesterday and drove it around to make sure everything was good, man what a difference in handling
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Save those GM ends... You'll probably need them when you go to put a D35 under there (it's a little wider).
JOSEPH169
12
Marysville, Wa
I figured before as much and today we had an 94 explorer come in on trade so I measured the rod end to end and its perfect for the gm and dodge links but not for the lil dana 28
Harley
Oregon
Ford bronco 2
5.5 in susp 2 in body
Anymore progress? Our builds are similar...like your steering setup....
Sent from my SKYTEX-SP1020 using Tapatalk
JOSEPH169
12
Marysville, Wa
Not too much as of lately, i just got my tax return so I can buy a commuter car so i can do more mods to this, I'm looking into getting some extended radius arms and upgrade the axles this year since I can take my time now.
JOSEPH169
12
Marysville, Wa
just an update
I've been looking for a dana 35 ttb to put in the front and extended radius arms. Its been on hold for a bit because school and such with the kid but i'll have my summer free to start working on it again.
Harley
Oregon
Ford bronco 2
Yea...im looking for the same stuff. ..waiting for something to come up on Craigslist.
JOSEPH169
12
Marysville, Wa
found a guy on cl that only wants $100 for his explorers 8.8 with discs. Just gotta go this weekend and pull it out.
Harley
Oregon
Ford bronco 2
Nice! Thats my next upgrade too...got the 35 already..
JOSEPH169
12
Marysville, Wa
Just got my 8.8 from the junk yard. The guy i was gonna pull it off of had broken axles and didn't know if the housing was bent so I played it safe. Now time to relocate the spring perches and weld shock tabs.
JOSEPH169
12
Marysville, Wa
ok its been awhile since iv'e worked on the bronco but i got the 8.8 all spring down and cleaned and found a dana 35ttb on cl for $125 with the radius arms and all. Now i'm just waiting for my spring perch brackets and shock tabs to come from WFO and then I'm ordering some 4.88 gears for the front and rear and the front I'm gonna put and aussie locker in before i install it.
JOSEPH169
12
Marysville, Wa
Just got james duff extended radius arms
JOSEPH169
12
Marysville, Wa
Just got some dual shock hoops from James oaks. Now i just need to get some cash to get gears and then install everything.
