89 2.9 help!!!
rata209
I have a 1989 ford Ranger 4x4 xlt that is having some shaking issues. A little back ground within the pase couple years the transmission went out and i had it rebuilt and it only has about 10,000 miles on it since then. The problem i am having is when i take off from a complete stop i get a shake that feels like it starts right under the center consle and works its way back till its gone at about 10 to 15mph. I have checked and changed almost everything. I changed all the ujoints replaced the main drive line and had tires balanced. I am leaning toward something being wrong with the transfer case posibly not properly adjusted(can they even be adjusted?)corectly. the reason why i think this is becasue when i put it in 4wd it will shake violently when i turn kind of like the shake that i feel on take off nust on steroids. Can some one please HELP or steer me in the right direction.
THANK YOU
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Does it have auto hunts or manual hubs? Have you checked the u-joints in the axels? Is it a automatic or a manual trans?
scooter
October OTOTM Winner
50
N.W. Oklahoma
5.0L
Driveshaft u-joints or if its a extended cab check your carrier bearing. Both will cause that. Especialy the carrier bearing.
cmr2
Indiana central
2.9
checked the tranny mount bolts ,fly plate ,nothing there ?
