88 ranger ext cab vs 91 ranger dash
Oleskoolcarl
Howdy everyone new guy here I have a rusty 88 ranger ext cab that I bought with 26,000 miles on it 2.9 I bought it with the sole purpose of V8ing it the interior is Perfect I bought a very nice 91 extended cab I want to use my 88 interior and dash in it and Ac since my 88 stuff all works does any one have any info if this is just a remove and replace all parts ? Any info will greatly help
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Howdy, and welcome to TRS.
I meant to answer a day or so ago when I saw this but got distracted...but everything should swap over because the cabs are pretty much the same...some minor changes would be needed but I'm pretty sure it will fit with very little modification.
The 88 dash has a support bracket behind there that the later 89-94 cabs didn't have and there may be a bit of wiring hole mods as well as possible heater box swap needed. I put a 96 dash into my 88 cab and it needed a bit of mods to put in the heater box...the 88 box may be the same or very similar to the 89 and up but I didn't check that out when I had my 92 apart.
Just take your time and measure everything carefully...I took about a month to do mine and I was not really in any hurry...although I could have done it faster...I was just being overly cautious.
Oh, almost forgot...I do have some pics on my photobucket account if you need some reference....they are of the 88 firewall with the dash out and the cuts I had to make to get the 96 heater box to work...
Maggie may
I put entire 04 interior into my 87 f150 an issue was the shape of door opening everything fit except the trim on the a pillar. You should not have much problem . had 94 interior before this one. I have bucket seats from a Honda crx in my ranger.
Sent from my 10DTB12 using Tapatalk
Oleskoolcarl
Mark
Ty for the info I am definitely taking my time on it collecting parts here and there. Just got some 17 inch GT rims and going to do the interior first then the suspension 8.8 with locker and 4.11 gears 302 .30 over and a Richmond 6 spd trans I'll post pics of my progress soon.how can I view your photobucket pics ?
Oleskoolcarl
Maggie Mae
Ty for the info I'm hoping it goes well as yours did
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Just got the PM...the link below should get you there
These show the 88 with dash removed...what's behind...a bit blurry
http://i1179.photobucket.com/albums/x399/akwarian8/Truck Build/FirewallDriverside_zps34932d54.jpg
http://i1179.photobucket.com/albums/x399/akwarian8/DashRemoved_zpsad6d114c.jpg
http://i1179.photobucket.com/albums/x399/akwarian8/Heaterbox88_zps545f0541.jpg
http://i1179.photobucket.com/albums/x399/akwarian8/RustDriversidebelowwindshield_zps4b322caa.jpg
This shows the 96 dash removed...
http://i1179.photobucket.com/albums/x399/akwarian8/Pickering-20140512-00652_zpsee57cda2.jpg
This shows the hole I had to cut and then patch over for the electrical pass through on the firewall...so...be careful...:)
http://i1179.photobucket.com/albums/x399/akwarian8/Uxbridge-20140713-00722_zps3fce592c.jpg
This shows the 88 heater box holes that are in the firewall...can't seem to find the picture of the new holes but it may be on the computer that I was using...that I thought crashed but it was the monitor that died...so I can still get them once I get a new monitor...
http://i1179.photobucket.com/albums/x399/akwarian8/Motorin_zps14ffc643.jpgI have more but PB is not cooperating...you may be able to view the whole album but there was mostly shots of the engine bay and the two trucks I was swapping...
Hopefully that helps...looks messy but it's really simple as long as you keep the wiring in the dash and don't try to remove more than you need to.
