'88 Nissan "850" D21 HardBody
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
So I started with the Rears bushings., seemed like the right place to start to me. The old bushings came out fairly easy. And boy, were they ready to be changed out
60815
The bushings were stamped with part #'s, 9921,9922, & 9923. The 9921's were larger and obviously for the front, but the 9922's and 9923's seemed to be the same size, but I tried to keep like with like, and put the 9922's on the bottom, and 9923's on top. The tops slid right in with little force applied. The bottoms were a little more difficult. I eventually used a large C-clamp to squeeze the shackle through the bushings.
60816
60817
60818
60819
Old vs New
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
Adding gas struts to the hood ;
After several mock-ups, I have it complete. 2 struts.
So Here is what I did.
I bolted these home made brackets under the fender lip using 1/4-20 bolts and nuts. I used a 5/16' drill bit to drill the holes.
60820
This is the lower bracket/Driver's side.
60821
On the Uppers, I put the rod inside the hood hinge.
60822
complete, no hood rod
60823
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
When is the gtr swap?
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
So my old tires were from 2012 and super dry rotted. I had to search for a while before I found a "good" deal on a set of rims from a 2001 Nissan Frontier with tires that have about 50% tread left. He was asking $400 on FB Marketplace, but I offered $300 when I went to see them. One tire has a screw in the tread (still hold air) and the same rim has some damage. Looks like the caliper or something came off and dug into the aluminum. NOt a deal breaker by any means.
New rims in the bed
62291
62292
New rims in top pic, old ones; bottom
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Lt. Dan, you got new legs.
admit it, you said that in your Forest Gump voice.:p
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
Fixed the license plate lights. fashioned some brackets from some old gutters
Did a front bumper and valance swap
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
Also customized my gauge cluster. still gotta figure out how to get the tach working. My OE speedo needle broke about a year ago.
Also shave 100k miles off with the new odometer :headbang:
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Did you ever get a FSM off nicoclub?
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
Replaced the old disc style horn with a Trumpet style from an old (Early 90's) Mercedes Benz 300 SE
This is where it went, but I relocated it under the hood, on the DS fender, where all the Emissions stuff used to live. (No pic yet )
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
did you try the path for 87 or 88. they had 4 cylinder in them.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Does this have the sr20? The 1.8 pistons essentially drop right in for a good bump to compression.. coupled with a more aggressive cam profile, exhaust, Intake and tune would be right around 200hp.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
NAPS-Z 24 IIRC.
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
No
NAPS-Z 24 IIRC.
Yes z24. 2.4L dual spark plug I4
