3406pack
- May 3, 2011
- 0
- 1999-1988- 1973
- nissan- ford- f
Hello everyone. Long time lurker finally posting and I have a problem. My 88 BII with 2.9, 5spd, and 3.45 gears keeps throwing the 77 code and nothing else. KOEO comes back clean as a whistle with nothing stored. What got me to check the codes was it was sluggish up to about 2500rpms and then it would take off like it had 2stroke powerband. After the first code pull I came here and searched and found the ziptie on the throttle cable trick. I found I had .5in of slack and fixed it.Pulled codes again and same thing. So I take it by my local shop and they no longer have their OBD1 reader so after a test drive I was told to advance the timing some. I used their fuel pressure gauge and it read 38psi @ idle and 32psi @ 3000rpm so fuel pressure is good since I had changed the fuel filter and cleaned the canister. So I get it home and adv. the timing ( remembered to take out the spout and I find its still on 10deg b4 TDC.) I take it to 12 deg b4 TDC and it helps alot with the power loss But I run the codes and I get the same thing only now with idle out of range low. Ok back to square one. Put the timing back and back to same only code 77. I backprobe the TPS and get consistant voltage increase from .285 volts to 4.80 volt with no large gaps when rotated slow. Ran my scanner again and still code 77. Then I had a thought Unplug the computer and see if theres continuity between the plugs. Might have a broken wire somewhere ya know. Well I do and I find that there is good continuity between the TPS and ECM plug. Should I just say to hell withit,adjust the timing back to 12 and drive the piss out of it or is this something that could have some adverse effects down the road such as sucky fuel mileage. It wasnt that great b4 @ only 18.5 mpg on the country commute to work and back. What has been done to it so far is a good tune up, plugs, wires, dist. cap and rotor. I have changed the fuel filter and used 2 cans of seafoam. I put about 1200 miles on it since I got it from my parents and they didnt drive it much. They did drive it enuff to crack the heads about 15 yrs ago and had the motor replaced. Dont know how many miles it had but it kicked gas on fuel mileage for being as aerodynamic as a throwed brick. I apologize for this being so long but more info is better than not enuff. I thank you in advance for any help with this issue.
