- Apr 22, 2014
- Reaction score
- 157
- Location
- Ohio
- Make / Model
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 2.9
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 3in
- My credo
- Clean your room before you criticise the world.
I recently bought the truck already done so much to it mostly just fixing the stuff from the last guy I put a monster aod trans in it which turned out to be way more work than it was previously intended but got it done fixed the power steering setup quite a bit new pump etc i had to the aerostar steering shaft to make some clearance in there. currently I'm starting a Dana 44 sas swap I'll be posting up that too. but what's already done is a 8 in lift ( also not done right) small block Ford 302 lokar shifter advance adapters aod to borgwanner tcase adapter so I'm starting my build to post up for you guys and maybe help a few folks along the way
