87 ranger 5.0 swap
shortzt
So ive been reading this forum for months stocking up parts for my swap, i have an 87 supercab that had a 2.9 auto that i water logged, anys i figured its time to start a build tread.
shortzt
Np435 with a np205
302 out of a 76 f100
96 explorer 5.0 rad
Having fun installing the clutch pedal
I have all the parts to switch to dual sump oil pan and also have all the wiring,
shortzt
Also the only pic i have of the truck, any suggestions , i plan on doing a three inch BL and then newer axles but im only 17 with a budget
joeyd3713
Good luck
Is your old wiring harnes still intact? If so ill give 20 bucks and pay for shipping
shortzt
Yeah, and i have a guy getting it already i just have to Finnish stripping it out
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
The 96 rad wont work unless you bed mount it or mod the frame. Get a 91-94 explorer rad that had an auto trans. Get the entire 96-01 explorer 5.0 FEAD, use the 2.9 motor mounts with a set of plates. 3" body lift will help you install the motor, but might give you shifter issues. Stay efi, the wiring is easier than you think. The stock axles won't hold up long, upgrade to d35/8.8, both are bolt in swaps, since you'll need different driveshafts anyways...
SVT
shortzt
the rad fits fine with what i did to my core support, im running an electric fan setup and with how far forward my rad is ill have enough clearance for everything, next pay check im getting axles, shifter will be under the dash, look at dangerrangers for comparison, as far as efi vs carb, yeah i wanted efi but i got everything for the carbed motor ignition and everything for $300, and plus all my friends are into mud and run carbs so parts and carbs are cheap eventually itll be efi , but thatll be with an H.O stang motor not a non roller motor right now im just going cheap on what i can and build from there its my dd or was my dd
shortzt
uploadfromtaptalk1405604417858.jpg]
Wonder what the fedex man dropped off
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
89500's or the 88400's? Time to stop Ebuilding and start posting pics! Lol
SVT
shortzt
shortzt
88400's the only thing holding me up is the engine mount plates i gotta get some 1/4 plate,
shortzt
Well i was going to start building but ran into a deal i thought was to good to resist, got some full width f150 axles with 35s for $200 the kid also threw in some vert mounts uploadfromtaptalk1405972916953.jpg
shortzt
Well did a little more work, i didnt realize i would have to change a main cap bolt for the different oil pickup
Elutheros
129
Central Texas
Are those temporary freeze plugs in the block?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I was gonna say I'd install some freeze plugs before the block goes in...
SVT
