For anyone still reading this, I got my explorer 8.8 in today and the newer trans cross member, just need to finish up exhaust, get my heater blower motor box to fit right and then drive shafts and eventually front axle swap but it's slowly coming, stripped all the sound detaining shit off, figured out that is just a rust tap, got the flow down to bare metal and then painted
Pretty much got my shifter and interior buttoned up, need to get a couple mor bushings for the shifter, I didn't want to buy them all at first with out know if my plan would work,
Went to the junk yard got a rear drive shaft out of a 86 f350 and it was a perfect fit, put new u joints in and took the flange I had from an old bronco drive shaft, every time I break out the hammer and sockets I swear I'll spend the $90 for a ball joint press
Yeah, just a couple, most go into an ignition switch, to me it was easier to go with a universal ignition then the stock one, also I paid $24 for a damn u joint, only one I could find that I would have that day, it went from a 1330 to 1310
Got my Dana 28 out and got my 35 all torn apart waiting on bushings to put it in, really wanting to do a jeep sas but I already have a Dana 35 here, going to try to get a front CV yoke for my 205 at a junkyard tomorrow I hope to be driving it in a month or so, also put in new motor mounts, I would imagine that would be nearly impossible with out dropping the front suspension
Keep it coming!!! I know the 2 areas I'm going to have trouble with and lots of questions are how to hook up the C4 transmission/ Borg Warner 1350 transfer case linkage and wiring the new 302. You're doing awesome man.
Hooking it up won't be hard its the tear down of the c4 to swap output shafts and tail housing but luckily c4s are probably the easiest autos to rebuild, and thanks it's taken me allot longer then I have planned but part if it has been my fault
Well finally drove the truck, after about 8 months, it was great it was only a 100 yards but still, open headers are a little loud gotta do something about that and get the small stuff buttoned up
2 steps forward 3 steps back in a way, I put all new oil in everything, which is good but something was hanging up in the rear end, the inner brake pad is hanging up and not sliding also the e brake stuff was so I gutted the e brake I also noticed when I had one wheel off the ground I could spin it, so I'm guessing my trac lok clutches are worn
Well got my brakes figured out I'm going to the junkyard tonight to see what I can get for a fan I'm thinking either contour dual electrics or some sort of mechanical I have to measure and see, I burned out some shock mount brackets for the rear axle today
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
