87 ford ranger 2.9 4x2 5 speed manual reg cab
wagonho
I need to know if my ford ranger's fuel tank is a mid tank or aft axle tank installation. I need to buy a new oem fuel pump. Truck is located in Virginia and I'm in Texas so I can not look and see which type installation my truck has. I hope someone can help me. Many thanks.
If you don't have dual tanks then it is mid-ship. If you have dual tanks it could be either, and you need to know which tank you are dealing with before you can know which tank you are dealing with.
saskbill
6
Saskatoon, SK CANADA
If the trck only has one factory tank, it will be a mid tank. As far as I know, on Gen1 rangers, rear tanks were only used on dual-tank setups and Bronco IIs (different tanks used on BIIs.)
I know that you don't have your ranger handy to look at, but dollars to donuts, if you have a picture of it, the filler flap will be at the front of the box, not the rear...
