87 Bll heater fan switch issues
moosemeadows
My 87 Bll has a heater fan issue. It was only running with two speeds rather than four. One day coming home the fan quit all together. I was able to get it running again by switching the heat/vent switch back and forth a couple times. I reasoned that the switch was going bad so I replaced it with a new one that had a a/c button on it like my 85 with add-on a/c. Still did the same thing two speeds only med & high. Next to be replaced was the resistor and figured why stop there and replaced the motor only to end up where I started with 2 speeds. What did I miss?
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,663
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
What does the connector to the fan look like? If it's setup like in the Rangers with the connector in the engine bay, they get corroded and eventually short.
moosemeadows
I looked at it and seemed ok. No corrosion.
Josh B
1,986
Oklahoma
It's not a slider is it? Those get corroded too, just take it apart and clean it up was all they took. Some reason I also supposed a connection in there somewhere
ford4wd08
510
Alcoa, TN
2.8 V6
Did you try just grounding the fan to see if it would run at top speed?
Which speeds do you have?
moosemeadows
I have medium and high
ford4wd08
510
Alcoa, TN
2.8 V6
Usually when you have a resistor issue you only have hi.
I think you mentioned it already, but maybe cleaning contacts or checking switches, grounds?
