87 bII broken rear driveline
Iceman21
Brewster, WA
Bronco 2
2.8L (soon to be 350) and 2.9L
Hey I broke the "pop can and toothpick" style rear driveshaft on my 87... I have an 84 b2 that has a fresh drive line (orv, parked for winter) but its the slip yoke shaft with the double u joint up on the case... Can I just swap the drive lines? The 87 is my DD and snow is here And I can't run just FWD... Help is greatly appreciated
70roadrunner
8
sedro-woolley, Wa
1970
194
plymouth
2.8
it should bolt right in. if your ORV has a lot of lift, it may bottom out the yoke and cause damage. only one way to find out, get the wrenches out and try it!
Iceman21
Brewster, WA
Bronco 2
Thank you! Also, the 87 output yoke is a flat flange.. The 84 isn't... It's the double carden. Think I could get away with removing the middle peice of the double and putting a flat flange on the remaining u-joint? That way I shouldn't have to swap yokes... Right? Sorry I just don't wanna tear into everything and find out I coulda done it simple haha:icon_cheers:
