86 bronco II 2.9lv6 no start
SmokeyBroncoII
Alabama
I would like to start off by saying that if I spray ether in the intake it will start. O have a fuel pump ( it is wired in by it's self to eliminate a power issue there) hooked up to a external tank. I have a strong blue spark on all 6 plugs and fuel in the fuel rail. I amde my own pulse testor for the injectors when I had the fuel rail out to clean it and they all had a decent spray pattern. I hooked a test light up to each injector plug and nothing. With that being said the carpet around where the computer is located is wet could the thing run on ether with the computer being bad. It has been sitting for 23 years
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
Yes it would run on ether if the ECM was bad.
I know theres some injector grounds that bolt, i believe to the intake plenium. I would check those connections/wires first.
You can pull out the ecm and actually pull the cover off it and look for moisture damage inside.
SmokeyBroncoII
Alabama
Grounds are hooked up so I guess that means ecm is bad anyways I'm headed out to my shop to pull it I'll take pics and post them cause I'll have no idea what I'm looking at
SmokeyBroncoII
Alabama
There is rust on the outside of the exam and rust on one of the capacitors on the inside guess the ecm is bad
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
SmokeyBroncoII
Alabama
The capacitor was rusted so bad that when I picked the computer up to get better light I fell out so I know it just has to be bad now
rusty ol ranger
2.9 Mafia-Don
7,578
Michigan
177 CID
If youre junkyardin youll need an 86/87 2.9 ecm. 88-92 has no EGR, you can use an 88-92 but youll haveta disable/block off the EGR system.
SmokeyBroncoII
Alabama
Thank you i was reading something about that last night
SmokeyBroncoII
Alabama
There is no ranger or bronco 2 with a 2.9 in a junkyard within 75 miles of me so Craigslist it is
SmokeyBroncoII
Alabama
Do you think it could be a ground some where that's what it seems like it is to me
SmokeyBroncoII
Alabama
Ok I have went junkyardin picked up a running 2.9 and the ecm out of the ranger swapped everything over and I still have a no start situation. I have spark but I am still not getting power to the injectors. Could it be a bad ground that's what I think it is, anyways thanks for the help so far.
OK, since all the injectors get power from the same wire, start tracing it back and find out where it is broken.
Uncle Gump
Token Old Guy
13,493
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
It's important to note that the injectors receive a constant power source... the ECM will then pulse a ground signal to activate the injectors.
SmokeyBroncoII
Alabama
Ok just a little update. I rechecked and cleaned all grounds with a wire wheel on my grinder. I went and got a new computer control relay and the green relay (can't remember what it goes to) and now all it does is backfire like a mad man I did have a few plug wires on the wrong plugs so I looked up the correct firing order and got all wires where they are supposed to be and it still backfires. I am at my wits end with this thing. where is the ground fe the back of the block supposed to go on the fire wall or does it matter. I do greatly appreciate all the help you guys have give me.
JerryC
56
Tennessee
2.9
Over on the corral a guy followed the firing order but was off one place on the cap. He was told to check tdc on cylinder one to be sure where the number one wire connected.
