- Aug 7, 2007
- 17,868
- SW Iowa
- Ford
- Engine Type
- V8
- Engine Size
- 5.0
I did a little looking for giggles, right now the only E7's on craigslist kinda locally (1hr away in Omaha) is a pair of bare heads with 70k miles on them for $100. I would still need valves, springs/retainers, pushrods, and rockers to make them work... not much of an advantage compared to sending the 289's thru the shop.The difference is going to be on how good the set of E7's is to start with. You know your 289 heads are going to need new valves. Chances are if you're careful in shopping, you can get by with a set of E7's that only need a valve job after porting. That's what I did with the sets I ported. The only out of pocket expense on the first set was $50 for the heads, about $70-100 for the valve job, plus whatever I spent on porting kit and a set of long stemmed carbide porting bits.(which I've since used on at least 4 more sets of heads) I put $150 in those heads 8 years ago, they're still running now on a second build in my Ranger. I also topped em off with a used set of Cobra roller rockers (also bought used with over 100K miles on em) All told, I invested $250 in these heads and rockers. And still enjoying them after 8 years.
I still haven't decided which way to go for sure yet, the thing had 8.4:1 compression stock with the D8's, maybe if I mill them, do a valve job (cost would be nill to grind the valves because we have a valve machine) and match the ports that wouldn't be too bad of a way to go either.
