brownranger
- Sep 15, 2016
- 0
- Ford
Hi all. mew member here. I've been searching for days now and have read tons of stuff about the fuel pump/system. I still have some questions I'm hoping you can help me with. I can't find a diagram of the fuel system anywhere I have looked.
Some background: This is my first Ranger. I bought a 1985 Ranger with the EFI 2.3 and auto trans. It's been sitting since 1999. So, I decided I was going to pull the bed, drop the tank and replace it and the fuel pump. Inside of the tank is nasty.
The truck has one of those black reservoir or filter housings in line between the tank mounted pump and the in line high pressure pump on the frame. After reading all this stuff about the pump and reservoir, I've decided to scrap all that crap, as folks in the V8 conversion forum suggested to others, and install a single, newer vintage ('89+) in tank high pressure pump. Ya with me so far?
So, my questions are......
1) will the existing lines from the old in tank pump (with the old horse shoe style retaining clips) work on the newer style pump and be up to the job of the higher pressures?
2) What type of lines/fittings should I use to fill the void where the black reservoir and in line pump used to be?
3) Is there a diagram of these fuel systems, specifically the fuel line routing?
I'm used to, and much more comfortable with, old mechanical fuel pump systems. This high pressure stuff with these weird and stupid clip connectors concern me a bit. 5 or 6 different kinds of fittings......high pressure vs low pressure line and connector questions....etc., etc.
Thanks for your help and advice. I'm kind of a dummy who over thinks everything and generally has bad luck with every aspect of life. Today was no exception.
