Dustinicus
- Aug 21, 2013
- 0
- ford
- Engine Size
- 2.3
The stock cast manifold broke in half while i was replace the exhaust system;
I found a steel tube header on a 93',
I made a plate from sheet metal to block the smog pump holes that run underneath each of the exhaust ports to the atmosphere;
it seemed to work, but now i get the feeling that it may still be leaking under one of the ports. there is a clicking noise at 1/2 or more throttle but only at high speeds. It sounds like something is going to rattle apart inside the engine
I would like to figure this out so I can play with things like porting, bigger injectors, and a little more power
Can anyone give any advice for a better blocking plate idea?
Or suggestions for this issue?
Truck runs great otherwise
thanks
Dustin
thanks
Dustin
