84 bronco 2
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
i was wondering how fast i can go in each gear cause i hate trying to pas in 4th it has the 2.8 with the 4 speed
martin
26
St Bruno, Quebec
1991
There are too many variables involved to give definite speeds (gears, tyres, etc). Easiest answer is to install a cheap tach, Walmart has them for a few dollars and they're easy to install. However, the 2.8 is quite happy to rev pretty high, you'll feel the power start to drop off before you get to rpm's that will hurt the motor and you'll want to shift anyway.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
well the thing is u still have to set a tach once u get it its not just plug and play and everything is stock it ha 4x4 man hubs it is a base model so it probabaly has the 3:75 or whatever the gears are that everybody wants to change if u get bigger tires
chrwilkins30
6
Mishawaka, Indiana
2.9
It prob 3.73's. Just FYI so you know. Anywhere from 2000 to 3500 seems like a good option. Enough power but not so much your wasting gas.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
ok i will have to get one how do u hook it up
martin
26
St Bruno, Quebec
1991
They all come with instructions. The easiest way on the 2.8 is to grab the 12v and signal wire from the coil, then you will just have to find a ground. You can attach the light wire directly to the 12v if you don't want to go searching for the dash light wires. You should be able to install one in about ten minutes, a little longer if you want to get fancy.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
ok i will have to wait a while cause the cheapest ones i find are 54 plus shipping
