83 manual to power steering ?
rab
merkur
im looking at buy a 83 ranger, it will get a 2.3 efi turbo swap.
i want power steering also, so what are my options and what will bolt up or work with slight modding.
also do you guys have a list of different options some where and what years came with what pumps, boxes,racks ect, any oem/stock upgrades?
Insanejughead
33
Missouri
'94, '86
2.3T
I don't know about other pumps and gears that will work, but a power steering pump and gearbox that you pull off of another ranger will be a drop in and bolt up affair.
One from a yard that hasn't been damaged and isn't leaking fluid profusely will be almost lickety split to bolt into your ranger.
Some people have done swaps to other steering gears, but I know nothing about them.
I'm glad to see you asking around and all that.
rab
merkur
are all ranger steering boxes the same ie 83-92 all models,ect,?
are all ranger pumps the same all models?
are the pump brackets the same thru the years that have the 2.3?
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
All Ranger Power Steering boxes 1983-97, Bronco2 from '83-90 and Explorer from 1991-94 are exactly the same.
BTW, 2wd Pitman arms (the arm on the steering box) are not the same as 4x4 pitman arms
and the one on the manual steering box is a unique spline that will not fit anything else
If you are doing a turbo engine swap use the "front dress" off of the ranger engine
The "Front dress" of an engine is the pullies (ALL of the pullies), accessories
and associated brackets.
AD
rab
merkur
AD
o.k. thanks, will a power box fit my 83 manual steering coloum, or do i need a coloum out of a truck that had p/s from the factory
Insanejughead
33
Missouri
'94, '86
2.3T
The only thing that matters would be the intermediate shaft that mounts in between the steering box and the part of the steering column that sticks through the firewall. They're the collapsible piece that has a through-bolt on one end and a pinch bolt with splines on the other end.
Allan can correct me if I'm wrong, but there should be no differences in the intermediate shaft design between the '83-97 years. I'm using a shaft out of my old '85 in my '94 right now. The '85 was power steering, and I swapped my '94 to be manual.
rab
merkur
Well I can confirm, I swapped a 90 power steering box and intermediate shaft into my 83 that had manual steering, along with still keeping my stock 83 column.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Cool...I just went the other way...took a 96 steering column and put in my 88 manual steering box and pieced it all together on a 96 frame...used the 88 cab.
The only problem I found was the 96 column sat a bit higher than the 88 would have so I had to lift the body by 1" to get it to pass through the center without mangling the firewall on the 88.
I just prefer the feel of the manual steering over the power steering...although it takes a bit more precise calculations on approach to say parking because you really don't want to have to go back and forth too much...but I'm already used to that.
