8.8
troymn
Hi, Looking at updating from a 7.5 to a 8.8 limited slip on a 1997. I plan on a ranger axle not explorer. My question is what is different with the newer axles (say a 2002)? I look at car-part.com and it will combined 94-97 and 98-02. Is it the abs connector? Will it bolt up and will the cables for the e brake work? If not what needs to be changed to make it work correctly. Thank you for any help!
17,890
SW Iowa
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
×2, I'm not aware of any differences whatsoever among '93-'09 Ranger rear axles other than both the 7.5" and 8.8" were offered. The confusion probably does come because the fronts were changed quite radically for '98.
'93 is when the rear became 2" wider than the '92 models.
troymn
Thanks guys!
Will
514
Gnaw Bone, Indiana
Toyota
But don't do it. There's nothing better about a Ranger 8.8 over a Ranger 7.5 . Being a semi-float axle, all the weight is dealt with through the shafts, which are the same in both axles. They put a taller ring gear in behind he 4.0 engine,but the 7.5 has always held up well even with V8 conversions long before the 4.0 was offered.
A 7.5 axle will hold up to almost anything. It's not where you should put your money to make the truck better.
An Explorer 8.8 is an upgrade because it uses the same axle diameter and bearings as an F150 so it has a lot more weight capacity.
I would bet for an offroad Ranger, the 7.5 would handle any tire you could get on a Ranger. Might not have good gearing options, though.
17,890
SW Iowa
Gear selection, better locker selection maybe and stronger pinion gears in the 28 spline 8.8... and it bolts in.
Yeah, the 7.5 is a strong axle for it's size, but the available gear selection sucks. Locker selections are non-existant.
pjtoledo
2,970
Toledo Ohio
Fords
3.0 2.3
I'll add that my 2005 reg cab 2wd is about to hit 300,000 on its 7.5.
I run 235/75-15, and always had 500 lbs of tools in the bed.
Auburn gear offers a LSD, Detroit Truetrak has a listing too.
Perry
troymn
I appreciate the advice
