8.8
dirtyzj
i bought a 8.8 out of a 94 crown vic
i got it for dirt cheap and it has disk brakes. Does anyone no if explorer 31 spline axles are the same length
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I don't think they are, although it wouldn't matter anyway for swapping, the Vic is 28 spline, the Ex 31, which means the wheelbearing sizes are different.
To convert that axle to 31, you'll need custom shafts made for it that use the 28-spline-size bearing journals. (Moser, Currie, Dutchman, etc. sell such shafts)
dirtyzj
well what if i just get the 31 shafts that match out of the write year and get the 31 spline bearing and seals.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I'm not sure, does a 31 spline Crown Vic axle even exist? :icon_confused:
The bigger bearings still wouldn't fit your housing though (and I don't think you can swap the housing ends either, the tube sizes are different).
If you were thinking of getting Explorer shafts, just get the whole Explorer axle. It'd make it a far easier swap.
mkpecor
black diamond W.A.
ranger 4x4
2.9
+ 1 what 4x4junkie said.
mhughes165
9
302
depending on what you plan on doing with the truck i might if i were u just run it even if it is a 28 spline axle.....i mena u already got it, with disc brakes......why pay for one from a explorer, and then u cna be different aswell
chvlfrk
December 2010 STOTM Winner
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
5.0L
235/70R15 front / 275/60R15 rear
Curious>>>>
What's your reasonin for the CrownVic axle other than price?
I'm lookin to pick up same type of rearend, but purely for the disc brake setup, as I have a 92 Explorer 8.8 w/3.73 posi & drums, and plan on puttin the disc brake setup off the CrownVic on it.
