8.8 driveshaft
stevenf
The 8.8 uses a Flange and instead of a yoke. What adapter can I buy to make it fit my 89 BII driveshaft? Where can I get it from?
engdept
5
Charlestown, IN
2.9
You should be able to get a flange adapter from any drive line shop. I got one for my Explorer 8.8 for $25 here locally.
You can also get a yoke for your 8.8 from Jeg's if you want to go that route. It is more expensive, but from what I have heard the yokes are stronger than the flanges.
http://www.jegs.com/i/Strange Engineering/873/U1630/10002/-1
stevenf
Could you give me a little bit of detail so I will know what im talking about?
I know I need a flange to yoke adapter. Im sure there will be different sizes. How do I know which one? Are there different length as well? How do you measue sizes of U-Joints?
engdept
5
Charlestown, IN
2.9
It is best if you take your drive shaft to the shop and tell them you have a flange on the axle with a bolt cross dimension of "x".
What is your dimension from end of cup to end of cup on your u-joint? I have a stock Explorer u-joint/flange drive shaft end I will sell you if it works.
stevenf
I dont know the dimensions yet, I havent taken it off. It is the stock 89 BII U-joint though.
engdept
5
Charlestown, IN
2.9
It would be cheaper for you to get a 1310 u-joint flange with a cross bolt pattern of 3.5" I believe. You will have to measure the cross bolt pattern on the flange. Like I said, I got mine for $25 locally.
stevenf
What is the 1310? Are they part numbers? size categories. U-joint sizes/models?
engdept
5
Charlestown, IN
2.9
A 1310 is the size u-joint you currently have in that drive shaft. The drive line shop will need to know that to give you the proper flange.
stevenf
My BII's stock rear has a pinion flange. Does this mean I dont need an adapter like most sites say or I still need a different bolt pattern?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Grab the u-joint flange from an 8.8 equipped RBV and replace the flange on your driveshaft with it, problem solved.
stevenf
Will the stock U-Joint fit the explorer flange piece?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
