- Dec 21, 2008
- Reaction score
- 7
- Location
- Auburn, Wa
- Make / Model
- Ford
- Engine Size
- 3.0
- Manual
Im putting this in the non-ranger axle area because I feel its more appropriate.
Before I get flamed for bringing this up, I wanted to say in my defense that I have been thinking about this for awhile and the idea came to me due to the lack of other options I have come across in my area.
I was looking into a 6" lift for my B2 when the thought struck me that instead of spending $1200 or more on a TTB lift that I could get away with spending a lot less money if I SAS'ed it. Now the only problem with that is that I cant seem to find an EB axle and even then I would have to modify it, and I have noticed a few HP44's in F150's at the JY but I would have to modify those moreso than an EB, Not to mention the cost of a locker and gears for the 44.
I got to thinking after looking at my extra set of 4.10's on the shelf and seeing a jeep around my area with 9" front and rear axles, why not make a hybrid axle myself.
I already have a 97 explorer rear axle with 4.10's in my shop I was going to use for the rear. I was thinking of going out to the yard and picking up another explorer axle for around $100 and also picking up a front 44 out of an F150 or something also for around $100. I could drill out the plug welds and remove the tubes from the pumpkin and that would leave me with the chunk that I could re-gear with my other set of 4.10's. I could pick up some 3" .5" wall pipe(tubing) and make new tubes. Then I could either: A)Bore out the D44 knuckles to 3" or B) turn down the tube to 2.75" (I have the capability to do both), and attach them to the new tubes. I would run all the F150 outer stuff with new shafts to fit the 31 spline carrier.
Why go through all the trouble when I could just use the 44 and mod that right?
Well I could use the locker from the 8.8 (free), and the gears on my shelf (free). I would have to spend anywhere from $100 to $200 on a locker for the D44 plus the cost of gears and that could be anywhere from $100-$150.
I would have to get new axle shafts either way, and the 31 spline from the 8.8 would be bullet proof on that end. The only downfall I see to the 8.8 setup is that it would be a Low pinion setup, but it doesnt seem that people have too many problems with LP setups.
To me I see the 8.8 setup as being cheaper and more unique. Am I out to lunch here?
