8.8 and Dana 28 combo question
Leadchunker
Lawrenceville, GA
2.8
I bought an 8.8 rear end from a 97 Explorer for my 84 Bronco II. I know it is about 3" wider than the Dana 28, is it worth the money to find a Dana 35 or can I set up to run the Dana 28 as long as the gear ratios match. I got the 8.8 with 3.73 gears and disc brakes for $100. I just thought it was a good deal. I still need to get a flange to connect the drive shaft and do some fabricating on the spring perches.
4.0B2
151
Walls, MS
4.0 v6
you can use the d28 as long as its geared the same.
personally, i say don't spend ANY more on the d28... just find a 3.73 d35 in a junkyard and swap it out. its basically a bolt in swap. a d35 is a HUGE step up over a d28.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
that, depends on what you're planning on doing with the truck too. the d28 is a giant turd though, def dont pay to have it regeared
4.0B2
151
Walls, MS
4.0 v6
if you have any pull a parts or u pull it type places around you... find a d35 3.73, its easier than a regear and if you can get a good axle, its probably cheaper or just as cheap as a regear.
trail B2
8
North Eastern Ca.
A 35 is money well spent.
Leadchunker
Lawrenceville, GA
2.8
Thank you for the advice, there is a pull a part about 15 miles from my house. One other question, will the rough country 4" lift work with the 8.8 and dana 35? I am taking the body off the frame next week and thought I would replace the body mounts and paint the frame. Figured I might put a lift on while the body is off.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Should work fine. Only thing would be if you get new rear axle u-bolts, they'd have to be for an Explorer or F-150, not a BII or Ranger (larger axle tubes).
Have you looked at the Skyjacker or James Duff lifts at all? (or even Tuff Country?) I ask only because Rough Country's lift is known for damaging D35 axle housings.
Also just a FYI, the Ex 8.8" is 1.5" wider than the D28 (59.5" vs 58" for the BII axles). The D35 is 59.5" wide, but mounts the same as the D28.
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
I used early bronco application u bolts for mine with the AAL installed. Stock explorer 8.8 u-bolts will work fine if you run standard leaf packs with no block.
Leadchunker
Lawrenceville, GA
2.8
Thanks for the information, I will check out the other lift kits.
Leadchunker
Lawrenceville, GA
2.8
I have found a Dana 35 with the gear ratio to match my 8.8, the only problem is it has automatic hubs. I think it is from a 96 or 97 Explorer. Can I use this on my Bronco II and change the hubs to manual hubs or do I have to use a 91-94????
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
explorers only came with D35's from 91-94. rangers had them until 97. you can swap out the auto hubs for manuals for less than $100.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
explorers only came with TTB D35's from 91-94. rangers had them until 97. you can swap out the auto hubs for manuals for less than $100.
Small correction
'95up still have D35s, but not one that would work under a BII.
I suspect he may have the year wrong though, as '95up ones also don't have auto hubs, they either have a CAD unit, or nothing at all.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
Small correction
true, but in the OP he was talking about replacing his D28, so i didnt figure he was trying to throw an IFS setup in there
No members online now.
