- Aug 17, 2007
- 4,478
- central ohio
- ford/escape
- Engine Type
- 2.5 (4 Cylinder)
- Engine Size
- 2.5/151 I-4
- 2WD / 4WD
- 2WD
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
just got a new-to-me 94 2wd reg cab longbed, has a 2.3, 5 speed, and a 7.5 rear axle with fiberglass leaf spring and (yuck) the 3.45 ratio. id prefer at least a 3.73 gearing, or 4.10's (looking at ditching the 225/70 14's for 235 75 15's) im not sure if id be better off regearing or swapping out the whole assembly, i know id get the bigger 10" drums with a 8.8, not sure if i will need to get a normal steel spring pack and ditch the single fiberglass leaf or not. plan on putting axle mounted coil helpers, so i dont think the fiberglass leaf will be a problem. unless it has to go because of mounting issues with a 8.8
