66-77 3.5" lift coils
RougeRanger
Do you know if this is too much lift on an extended cab 3.0 4x4. I found some 3.5" lift coils for a early bronco and curious if it's going to be too much lift to get the fronds end aligned without major mods.... I've read where u can replace with stock b2 coils but nothing about this.
Any info would be much appreciated.
RougeRanger
Edit: So I am planning on using extended shock tower and spring buckets. I am not sure how much higher those are than stock but I've located some 3.5" lift coils and shocks for a 66-77 bronco 2 and planning on trying to make it all work hopefully....
Btw this is my first build ever and kinda winging it but we will see what happens once I get the parts in hand!
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Winging it, eh? no better teacher than experience.:icon_thumby: Trial and error and all that, but I'm sure some one will know what you're asking, if it can be done, it probably has been done.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Do you have a link to the 3.5" coil springs you're considering?
RougeRanger
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I think you may be taking a gamble with those... (I'm not familiar with K bar S)
With adjustable buckets you'll probably be able to find a setting that will work for height (camber), though without knowing their spring rate, there's no telling what you'll end up with (you need something around 300-325PPI for your Supercab truck, many EB springs are well-under that). Too soft and it's not going to handle well. Plus if their quality is mediocre, they may sag out and not hold alignment.
Something like this where specs & quality are known is what I'd look for:
https://shop.broncograveyard.com/Ford-Bronco-Ford-Truck-Super-Flex-Coil-Springs-5-inch-Lift-CSH57/productinfo/23209/
By my calculations, those should work if you can set your coil buckets somewhere between 2-3 inches higher than stock on the frame, which should provide approx 4 - 4.5" of lift, and would work with a set of 4" lift axle brackets + extended radius arms.
You DO have something planned out for your steering, correct?
RougeRanger
Well honestly I've read a bit into your sticky and realize it will be an issue however no I dont have plans yet...
At the moment I am just going to stack some washers under coils, weld the rear and take her wheeling for the first time and make sure the motor and such will hold up before I drop much money into it since I am just a broke country boy!
RougeRanger
Also with 4" of lift wont I have to do some mods to radius arms? I'm looking for cheapest route a d searching for junkyard parts such as f250 shock mounts and some kind of raised spring perch without having to buy 1 new!
Is there a certain year Ford used those on the f250s?
Also with the 64" Chevy leafs, is there a certain year model I should be looking for?
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Good plan. Make sure the truck is in good shape and that you like it.
Extended radius arms are needed to take full advantage of flexier coil springs like EB or Jeep springs. Without extended arms you may as well just go with regular lift springs that are made for the TTB suspension (of those, Skyjacker seems to be the best).
I believe it's '80-'97 for the F-250 shock mounts (certainly '92-'97), and '88-'98 for the 64" Chevy leaf application (K1500).
swynx
9
lewiston idaho
Mazda
i run some bronco graveyard 3.5 eb coils, they are actually made by skyjacker. they are 320 ppi. they ended up giving me 3 inches of lift, and i only wanted 2 inches. so i had to raise my coil bucket 1", then max out my alignment deal. they work really good tho.
No members online now.
