99_3.0
- Nov 29, 2008
- 2
- Age
- 36
- Glenwood, MN
- Ford
- Engine Size
- 4.GO!
I was reading up the tech article about it. In the bottom pictures where the suspension is at full droop, when the shackle contacts the bottom of the hanger, wouldn't that create leverage where the shackle bolts to the hanger? Would this be enough of an issue to break anything? I suppose the only force this would sustain would be upward, away from the bottom of the hanger. I would also have to run a lift leaf so I wouldn't have my tires sitting in the top of my fenders on flat pavement. Currently with stock leaves, belltech 6400s and a 2 inch block I have about 3.5 inches of lift, more or less. How big of lift leaves would I need to clear a 33 and not grenade my fenders? I will be using some sort of bumpstop as well. I would be interested in doing this swap after I figure out these questions. Thanks a ton!
