5 speed transmission replacement
rangerpam1
kentucky
2.3L
My husband is replacing the 5spd manual tranny in my 1994 Ford Ranger. It has the 4 cylinder engine. He's having problems removing the hydraulic line fromt the clutch slave cylinder. He's got the service tool to release the quick disconnect fitting. The ring compresses but the line won't release. It appears to be the Mazda M50D-1 transmission according to him. Any suggestions about removal and intallation based your past experience would be greatly appreciated.
Thanks!
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
I prefer to push the collar in with 2 small screw drivers. There is no real sure fire way unhook the "quick" disconnect fittings I have ever found, just patients and luck.
sfwjesse
New Hampshire
if you dont care about the slave...then tell him to just pull with all his might. It will bend the little tang springs in the slave cylinder receptacle, but the master cylinder line should be fine.
Thats how I did it.
rangerpam1
kentucky
2.3L
Thanks, no luck so far.
CJREX
8
N. GA.
2.3 EcoBoost
2.3
Use the 2 small screwdrivers.
The factory tool doesn't press the plastic ring in far enough.
You can use the tool to get it started but that's about the best I've been able to do with it.
sfwjesse
New Hampshire
Drink a few beers...get mad...and PULL.
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Push IN on the line while you try to push the ring below flush
with the outer collar of the female half of the coupler.
Pulling OUT on the inner half while you pull makes it a lot harder to
release the barbs that hold it in place.
AD
