5 Speed Finally Went Out, What're my Options
65mechanic
2.3
Truck Info: 1995 Ford Ranger 2wd, 2.3. 5 speed, Ext Cab, Std bed
What's goin on guys. For the past, lets say, 4 months the transmission in my Ranger has been screaming like crazy in 5th gear, I was expecting something to happen. Well yesterday, going around 55 in 5th gear, I shifted down into 4th to pass a car, went to shift back into 5th, and it wouldn't come out of 4th. It appeared to be in neutral, but was stuck in 4th gear. Had to burn the *(#^ out of the clutch to get it off the road. The truck's ODO had stopped working at 331,660 miles about 3 years ago so I'm pretty happy with how long the factory tranny held up.
I'm not sure rebuilding the factory transmission will be my cheapest option sooo, looking at car-part .com and such, I found plenty of good transmissions from various years, but I dont know which ones will match up with no fitment issues. So, I suppose that's my question, what year 5 speeds will match up to my truck? Let me know if I need to provide you guys with any more information. Thanks!! :icon_thumby:
Earl43P
38
Farmington, Pa
Ford F250 4WD
You can use anything up to 1997, IF you want the speedometer to function.
http://www.therangerstation.com/tech_library/speedometer.htm
If you don't care to have a working speedometer (rely on your GPS for example), then you can use anything up to 2000. I believe the 2001 MY started the 2.3 Duratech, which may have a different bolt pattern.
Somebody more knowledgeable should reply about that bolt pattern change.
65mechanic
2.3
Awesome, thanks man. Would you know how early I could go? I'm looking at a 1990 and a 1992 5 speed in my area.
You can go as early as 88.
65mechanic
2.3
Awesome. Thanks guys. Plan might be changing with the truck. Might be buying it from my dad for close to possibly $200, lol. So I may throw a 4wd transmission to get the truck driving and do a SAS eventually. I'm assuming any transmissions from 88-97 will work? And I would assume the clutch/pressure plate/release bearing/starter/etc will be the same? I think the only things I'll need are the trans crossmember, driveshaft for the correct length truck, speedo cable, and a hole in the floor board. Correct me if I'm wrong. Thanks in advance guys.
You are wrong.
Only a 2.3L or 2.5L Lima transmission will work. 4x4 transmissions for those engine are rare.
Also, since you already have the M5OD you would not have any reason to change the trans cross member unless it is damaged.
rboyer
4.hoe
I should probably chime in and mention that you can use a transmission from after 1997 and retain your speedometer if you swap over the speedometer gear and tail housing from your original transmission. Not that big of a deal really either. Search around a little, there's plenty of info on this forums regarding these transmissions. Three things I would consider a requirement before installing an M5OD are shift rail plug replacement, shifter bushing replacement, and disassembling and cleaning the transmission. No matter how pretty it looks on the outside it's still not worth the risk of installing a live grenade underneath your truck and having to do it all over again.
rhekman
35
Lakes Country, Minnesota, USA
2"
I agree with rboyer. I'm in the process of swapping over the guts from a 2000 2.5L 4cyl into the M5OD-R1 backing my 4.0. Finding a 98-2000 4cyl 2wd Ranger or Mazda transmission in a junkyard with relatively low miles shouldn't be out of the realm of possibility. Then swap the tailhousing. Make sure to get the shifter with it. Better synchros, slightly improved shifter angles, all relatively bolt on.
