5.0 swap and SAS "Half-Pint"
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
Finished the power steering, it seems to be working just fine. No leaks. Getting pretty close to road-worthy. I’m hoping I can get it done by the end of the year. This is everything (I can think of) that still needs to be done before I can drive it:
Burn in track bar mounts
Steering shaft stabilizer
Put gears in front axle
Get driveshafts made
Front brakes
Front brake lines
Bleed brakes
Shock hoops
Rear shock mount
Shocks
Bump stops
Limit straps
Burn in spring perches
Gear oil
Torque suspension
Washers for radius arms
Fix heli-coil
Grease/torque radius arm caps
Grease steering
Replace fuel filler neck
Shifter boot
New headlights/ fix wiring
License plate lights
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
Cut shock hoops to fit. My welder is out of commission with a bent liner, got one in the mail. The drivers side was pretty tricky to fit. Also got some bump stops in the mail
34846
34847
34848
34849
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
Finally making some progress. I started the process of rebuilding the front axle. First step was to get a press. (Garage is a mess?)
38895
After a lot of cleaning I put the axle together with set-up bearings. I had to make a tool to hold the yoke.
38897
Took me multiple tries but I finally got a good contact pattern. Backlash is 8 thou.
38898
38899
Next step is to press on the new bearings and put the whole thing back together with seals. I’m waiting on a thrust washer, should be here Wednesday
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
39474
Got a winch! It’s a smittybilt, 12000 pounds
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
Got track bar brackets and shock hoops welded on. One of my axle shafts was too rusty to use, I ordered one from rock auto, should be here Thursday. Then maybe the axle can go back in the truck for the last time
39669
39670
39673
39674
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
The axle is done! Final pattern looks pretty good. The aftermarket hubs are a little off on the inside diameter, so the Warn hubs were difficult to get in, but they eventually fit and they work.
40510
40511
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
I also painted the shock hoops and made a steering shaft stabilizer
40512
40513
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
Got the axle under the truck. Been testing out the suspension without the springs to see how much travel/flex I’ll get. Without springs the axle flexes by a little over ten inches with the passenger side up, and fifteen with the drivers side up. That seems pretty good to me. I’m not sure what causes the difference between the sides. I’m hoping that once I put springs on it it’ll flex a little more on the passenger side, cause the spring will push down on the side that doesn’t have weight on it. As far as travel, it looks like the first point of contact is going to be the track bar touching the oil pan. By the time the suspension compresses that much, the coils will be pretty close to binding, so I think I’m good there. I’m not an engineer so I guess we’ll see!
40694
40697
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
Put in springs today, hopefully for the last time. Here is the truck sitting on wheels again:
40766
Also put on the brake calipers, and started working on mounting shocks
40767
Rooster
61
Dallas, TX
Solid Axle Swap 4x4
I have working brakes! Made some little mounting brackets out of square tube. The little clips that hold the line in broke when I tried to put them on, so I used 5/8 nuts instead. It’s a bit overkill but they’re not going anywhere😂
40847
40848
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
good work......
get the radimotatornator protector on there before you get too froggy with it.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i prefer not to run the lines like that though.
P93suafilo
14
Lehi UT
Do you have an example of how to run them. I am going to be doing this same swap soon.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
flex down the center...... hardlined out to the normal caliper flex lines
or down the radius arms.
setup in the manner these are i have seen them fail many times from whip.
