4x4 not working
rosscassavant1
ford ranger
i have a 92 ford ranger stx 4x4 when i press the button for the 4 wheel drive it dont do nothing. no clicking or sounds or no lights come on i just bought the truck so dont know about them thanks
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
First of all check all of the fuses and relays, I believe the 4x4 is a fuse, should be labeled in the fuse box. If that isn't the problem there is a 4x4 module in the cab somewhere (can't remember where) do a search as there's tons of 4x4 issues on here with this problem that tells where everything is and can help you diagnose the problem completely.
rosscassavant1
ford ranger
alright thanks i guess before if you press it a few times it would work then finally it gave out thanks
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Sounds like it may be the switch itself being bad. The actual electronics module that controls the 4x4 I don't think goes bad very often so the switch in the dash may just need replaced, or may just need the contacts cleaned even.
4.0B2
151
Walls, MS
4.0 v6
sounds like when the button was bad on mine... the overhead console, go grab one of those from the junkyard... or use a test light and see if power is making it thru the switch.
70roadrunner
8
sedro-woolley, Wa
1970
194
plymouth
2.8
my first electric shift 4x4 had an issue like that. i was gonna test the switch, and found that it was just not plugged in all the way. after plugging it in i found that there is a delay of a couple seconds before it shifts. hope this helps!
rosscassavant1
ford ranger
thanks i will work on it saturday and let you know what i find out thanks
a31ford
Electronics GURU
26
Brandon, Manitoba
Here, I'll give you a copy of the electric shift Transfer case diagnostics manual.
http://www.inetlink.ca/a31ford/xfer-case.pdf
it's about 1/2 a meg in size, so it might be a bit when it opens (you'll need a PDF reader like acrobat to view it).
Greg
