4x4 dont work, and light stays on all the time
4x4.Ranger
Drayton, Alberta,Canada
4.0L V6
was out wheeling in the snow and i went to put the truck in low range and the low range light came on for a second then both the low range and 4x4 lights went off. i shut the truck off and restarted it and tried to put in 4 wheel but the light turned on but it did not lock in?!? the truck says its in 4 wheel but it is in 2 wheel and the 4x4 light stays on all the time?!? the truck is a 94 4.0L any help would be awesome
-Ryan
toddk01
Oregon
4.0L V6
I can't remember the 94s that well. If it is an automated lock system, listen when you hit the switch for a clicking noise behind the glove box. That is the transfer case motor control module. If you do hear a click and the light comes on but no engage it is most likely the transfer case shift motor. You can try to rebuild the shift motor or bang on it :) (there is an article or two on here how to do that) but usually that doesn't work. I have an 02 4.0L and I had this problem. It turned out BOTH the control module and motor were both bad. Not cheap. Was a 600.00 gig. Ford recommends monthly engagement of the 4X4 system regardless if required to keep the parts moving. Hope this helps. :beer: -Todd
4x4.Ranger
4.0L V6
o i didnt even see that link in the tech library and i did what it said and i think its the module cause the red LED stays lit up but thanks for the help!
