4wd Not working, GEM module? No power to battery saver relay?
Mik
My 4x4 isn't working along with wipers dome lights and dimmers. I have no power to fuse 27. 4x4 motor works have power going to the relay next to the gem the dg/lG wire. I have no voltage to the battery saver relay. Fuse works in the engine bay and the cab
Stumped here. Should get power to the relay from the pcm because the fuse is lit but nothing.
Mik
So we found out if we jump the relay in the battery saver box we can get the dome lights to work. And if we jump the 4x4 relay separate from the gem in the connector we can get power to the motor. Also we jumped the washer fluid pump tonground and it worked off of the GEM
Are there any external grounds that the GEM module has? We checked the one in the engine bay that comes out of the harness going into the computer and bolts into the firewall.
BTW 1995 Ford ranger 3.0 splash
