Iffklg
- Apr 17, 2018
- 0
- Ford
I own a stock 2003 ford ranger xlt with an auto transmission 4.0v6 and the 4wd has not worked for the past couple years. I decided to try and fix it. The 4wd lights come on momentarily when starting the truck but do not light when the switch is turned. I hear the cm behind the glove box clicking when the switch it turned. I replaced the transfer case motor thinking it was the problem but it still won't engage. With the motor off and hooked up electrically it will change position with the switch. I can manually turn the selector on the transfer case with pliars and with it running in neutral I can hear it clunk into gear while I do manually select. I am at a loss now...
