4wd Hi/ Low indicator.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
So are you going to swap in a manual case? That would seem the logical thing to do if your worried about reliability. You can wire the lights up to work with a manual case, I did it on my 89.
arrabil
Lexington, KY
What did you wire to what? Thats a great addition to the swap.
Jspafford
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
When I got my manual case from the yard they had cut the harness for the lights. I had two wires about a foot long coming off the t-case. The connector is already prewired under the hood for a manual case. In my case on my Bronco II it was on the driverside fender close to the master cylinder. It was the only plug NOT in use with 2 wires in it. I just took some 14guage wire and connected them together with the harness on the case. I can take some pics if I need to clarify a little.
The exact locations of the empty harness may differ with model year changes.
arrabil
Lexington, KY
I think what you're describing is different than what I was thinking... You're talking about the instrument cluster lights, not the pushbutton switch lights, right? Your BII had an electric TC but the cluster lights weren't wired?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Hmm when I swapped my 88 to a manual it already had the correct plug underneath it to accept the manual t-case shift light, I just had to put the bulbs in the dash...
dogboy
14
Enumclaw/ Carbonado, WA
'93
In My original post, I was refering to the dash lights not the button lights.
I will probably be doing a manual swap some day, I just don't have money right now. The local yard wants 130 bucks, I think it was, for a manual 1354.
Id say thats a pretty good deal. A rebuilt one is like a grand isnt it. I was tickled pink when i found out my new (used) 1350 was only $85 with my discount ($100 for everyone else).
Jspafford
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
I got my 1350 from a local yard for $29.95!
The dash indicator lights and the lights next to the push buttons are wired in with the electric shift motor. When I wired up the lights the way I described BOTH sets of lights lit, the ones on the console and the ones next to the buttons. But then I took the push buttons out.
Hope that makes sense.
