4wd conversion?
steveoelo
Mighty Canuck
I know I already posted a thread similar to this but I checked under the conversion section in tech article and couldn't find what I wanted. I'm curious on if I can swap the transmission, transfer case, front axles etc out of a 4wd into a 2wd? Both are a 2.9 but one is a reg cab long box and mine is a extended cab. I know the drive shafts will be different but can it be done? What all would I need to change for it to be done? The donor drive runs and drives so swapping should be fairly easy
Engine cross member has to be swapped too. There are 7 or 8 rivets and 7 or 8 welds (total) that must be cut to remove the piece from the frame. It also requires removing the engine and getting the cab jacked up.
steveoelo
Mighty Canuck
Would the trans cross members need to be swapped as well? Mine currently is a Mitsubishi trans but I'm going to put a Mazda in
No, that should be OK.
