475,000 mile F7 rear axle
Paisano
136
Phoenix, AZ
Ford Ranger XLT
Ok. That's good that the ring gear size doesn't play into it. Then I'm good. Because I got 4.10 from front to rear.
Thanks Toledo.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,765
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Gear ratio is gear ratio. Ring gear size doesn’t matter, only the ratio does. You could have a Dana 28 up front and a 9” in the back and it won’t matter as long as the gear ratio is the same.
Paisano
136
Phoenix, AZ
Ford Ranger XLT
Nice. Thanks everyone. I am driving the truck now. The ominous sounds coming from underneath the truck are gone. But I'll reserve judgment until I've had several days to drive it.
I didn't have a good quality torque wrench to use on the leaf spring bolts. I made these reasonably tight. But not very tight. How tight do you guys make your leaf spring U-Bolts?
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
To the German Measurements ;
Gudentite
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
You should be fine. Use a paint pen and mark the nut and corresponding spot on the plate. Check a couple times to see if they move.
Paisano
136
Phoenix, AZ
Ford Ranger XLT
I can certainly do 'good-in-tight.'
And paint pen is exactly what I've been looking for
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
A kids crayon would probably last long enough to see any movement. Or use some finger nail polish...
Paisano
136
Phoenix, AZ
Ford Ranger XLT
I'll get the paint pen. I've tried crayon and it didn't really work out
JoshT
1,819
Macon/Fort Valley, GA
Since you don't have a torque wrench, before applying the paint pen I'd drive it a few days and retighten. If you are able to tighten, drive it a few more days and repeat, until they seem to stay tight. This will give everything a chance to settle in and retighten before applying the reference mark. From that point you should be good if you just check the mark occasionally.
Paisano
136
Phoenix, AZ
Ford Ranger XLT
Good timing Josh. Yes. I tightened the leaf spring U-Bolts twice more since then. This rear axle replacement seems to be successful. There were no less than 4 different abnornal sounds coming from the drive line. All these sounds are gone now. I lean my head out the window to listen when coasting, and all I hear is tire noise on the asphalt.
don4331
1,353
Calgary, AB
5.3
Paisano
136
Phoenix, AZ
Ford Ranger XLT
Oh.............I see. It's leading me into a false sense of security. As long as this false sense of security is a 10-year stretch..........................which it will be................Yes?:)
