4 cyl trans
bonerb
colorado springs, co
2.3
does it mate up to the 4.0? or can i swap the bellhousing off of a 4.0 rwd and put it on a 1995 2.3 trans
98mazdaman
Southern OK
Mazda
You should be able to switch the bellhousing off the 4.0 and put it in the 2.3, I think. Take a look. The 4 cyl trans is a little lighter duty to the 4.0 and probably not be a good idea to mate it to it, although it theoretically would work.
Wicked_Sludge
43
Westport, WA
3-point-GO
the 2.3 and 4.0 use a different bellhousing bolt pattern.
automatic transmission bellhousings can be swapped, but manual transmission bellhousings are a cast part of the transmission case...they cannot be removed. i wouldnt use a 4 cylinder auto behind a 4.0...it will not last long.
skyy_4life
Brooklyn Ohio
2.3 turbo
the 2.3l standard trans can hold up to like 400 whp so if u can find an adapter kit to make it bolt up straight to the 4.0l then i would do that. i dont know if they make an adapter kit for that.
scotts90ranger
4,373
Dayton Oregon
2.3 Turbo
they don't make an adapter that I know of, they're the same trannies other than the case and a different first gear ratio for the 4.0 manual tranny. as far as the auto goes, the 4.0 tranny is beefier than the other versions...
bonerb
2.3
cool thanks for the replies i will have to look for a 4.0 rwd trans manual if i need to the motor i have now is good so just wondering what my options were thanks again
